title: IP Ratings Explained
description: What are IP ratings and what do they mean for your fixtures? ETC provides a brief overview of ingress protection on the blog.
image: https://blog.etcconnect.com/hubfs/Lonestar%20Prime_rainfall-1.jpg
<https://blog.etcconnect.com/ip-ratings-explained#gwen-offcanvas-primary>
Search
[✕](https://blog.etcconnect.com/ip-ratings-explained#gwen-offcanvas-primary)
# IP Ratings Explained
![Quinn Wirth](https://blog.etcconnect.com/hs-fs/hubfs/Blog%20Images/quinn.png?width=34&height=34&name=quinn.png)By [Quinn Wirth](https://blog.etcconnect.com/author/quinn-buchanan) 2 Apr 2026
![](https://blog.etcconnect.com/hubfs/Lonestar%20Prime_rainfall-1.jpg)
What are IP ratings and what do they mean for your fixtures? Ultimately, they identify how much protection your gear has against dust and liquids. In this article, you'll find helpful tips to understand IP ratings and which might be the best for the environment you're working in. Let's dive in.
### What is an IP rating?![ETC IP Rating Chart](https://blog.etcconnect.com/hs-fs/hubfs/ETC%20IP%20Rating%20Chart.png?width=400&height=533&name=ETC%20IP%20Rating%20Chart.png)
An IP rating, or Ingress Protection rating, has two digits. The first digit indicates how well the fixture is protected against solid objects like dust or tools. For example, a rating of 2 tells you it’s protected against fingers and similarly sized objects. A 5 means it is protected against dust and 6 means it’s completely dust tight.
The second digit of an IP code indicates the level of liquid protection. This is especially helpful information if you are using a fixture outside where it could rain. A liquid protection rating of 1 indicates the item is only protected against vertically falling drops of water, while an 8 rating means it's protected against the effects of water immersion under pressure for long periods of time.
Let's look at an IP65 rating. The 6 tells you that the fixture has no ingress of dust. The 5 tells you it’s protected against jets of water from any direction, meaning you can consider this weather-proof.
### Pros and Cons of different IP ratings
It's tempting to think the higher the IP rating, the better the fixture for your application, but that might not necessarily be the case. Let’s run through a few different IP ratings and why they may or may not be the right choice for your production.
An IP20 rating has no water protection and only protects against solids greater than 12.5 millimeters in size, such as a finger. You wouldn’t want to use an IP20 fixture outside, but it might be perfect for an indoor setting. An IP20 rating often means a simpler design for service and maintenance, while having greater air flow throughout the fixture. With more simple maintenance, these fixtures will likely take less time to service.
An IP54 rating means the fixture is protected against dust and splashing water from all directions. These fixtures are not completely dust proof, but the lack of a vacuum seal means air, condensation, and humidity can move in and out of the fixture without getting trapped inside. And, you still can use the fixture in settings where it could rain.
An IP65 rating indicates the fixture is dust-tight, likely having a vacuum tested seal, and is protected against the rain. However, humidity and outgassing from components can’t get out of the fixture when there's a vacuum tested seal. After servicing these fixtures, performing a vacuum test on the dust seals can be a time-consuming process.
<iframe src="https://player.vimeo.com/video/1128291034?background=1" width="960" height="540" frameborder="0" allow="autoplay; fullscreen" allowfullscreen style="position: absolute; top: 0px; left: 0px; width: 100%; height: 100%; border: none;"></iframe>
### The ETC approach to IP ratings
When it comes to our products, ETC never takes a one-size-fits-all approach. Each solution is carefully designed with the customer and venue in mind. The IP rating of each fixture is a result of our design team balancing durability, usability, and cost to best meet our customers' needs.
Take [MegaPix and GigaPix](https://www.etcconnect.com/Products/Automated-Lighting/MegaPix-GigaPix/Features.aspx) for example. These fixtures comes with an IP54 rating to deliver high performance capabilities in an outdoor setting, while simplifying maintenance needs.
Take apart these pixel wash fixtures and you'll find IP65-rated fans, heat sinks for cooling, and a bellow system to maximize performance in rainy settings. Those interior bellows prevent water from getting into the housing, with no need for a glass plate to cover the fixture lens, so you can count on a clean, beautiful aesthetic from the fixture face.
MegaPix and GigaPix are intricately designed to move air through the yoke arms and the passthrough over the fixture head. This circulation of air reduces a common challenge in automated fixtures: outgassing. With a vacuum-tested seal, the gas released when interior components heat up and cool down can get trapped inside a fixture, often settling on the glass lens.
With the IP54 rating, MegaPix and GigaPix are a great choice for temporary outdoor use, like a festival setting. Users get all the benefits of simple maintenance and stunning looks, while trusting that the fixture is weather-proof.
Whether you're working indoors or outdoors, understanding IP ratings helps you make the right choices for your production. Looking for more resources about IP ratings? Watch the video below and share it with your colleagues!
<iframe width="560" height="315" src="https://www.youtube.com/embed/HyuUrlJVLdc?si=nNfwT-2F53qhQuxQ" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen style="position: absolute; top: 0px; left: 0px; width: 100%; height: 100%; border: none;"></iframe>
- <http://www.facebook.com/share.php?u=https://blog.etcconnect.com/ip-ratings-explained>
- <https://twitter.com/intent/tweet?text=I+found+this+interesting+blog+post&url=https://blog.etcconnect.com/ip-ratings-explained>
- <http://www.linkedin.com/shareArticle?mini=true&url=https://blog.etcconnect.com/ip-ratings-explained>
0
[#FEATURED](https://blog.etcconnect.com/tag/featured) [#GEAR](https://blog.etcconnect.com/tag/gear)
### The Tarkington Embraces Modern Lighting System with ETC
<https://blog.etcconnect.com/the-tarkington-embraces-modern-lighting-system-with-etc>
[Previous article](https://blog.etcconnect.com/the-tarkington-embraces-modern-lighting-system-with-etc)
### It's Always Tradeshow Season at ETC
<https://blog.etcconnect.com/tradeshow-season-at-etc>
[Next article](https://blog.etcconnect.com/tradeshow-season-at-etc)
![Quinn Wirth](https://blog.etcconnect.com/hs-fs/hubfs/Blog%20Images/quinn.png?width=180&height=180&name=quinn.png)
 Quinn joined ETC in 2018 with a background in marketing for K-12 and higher education. Studying English in college and tutoring writing across the curriculum fostered her passion for words and weakness for puns. When she’s not writing, she’s likely watching horror movies with her husband or plugging away at her goal of reading 50 books each year. A Wisconsin local, she loves seeing ETC products at work in Madison-area venues she has frequented throughout her life.
#### You may also like
[![](https://blog.etcconnect.com/hubfs/Full%20Compass%2050%20Years.png)](https://blog.etcconnect.com/etc-celebrates-50th-anniversary-with-full-compass)
### [ETC Celebrates 50th Anniversary with Full Compass](https://blog.etcconnect.com/etc-celebrates-50th-anniversary-with-full-compass)
 By [Quinn Wirth](https://blog.etcconnect.com/author/quinn-buchanan) 20-Nov-2025
It has been a year for celebration at ETC. We've come a long way since our founders began work on the [Mega Cue in 1975](https://info.etcconnect.com/megacue), bringing ETC as we know it to life.
[Read More](https://blog.etcconnect.com/etc-celebrates-50th-anniversary-with-full-compass)
[![](https://blog.etcconnect.com/hubfs/Apex_Body_Pillow_Hero_c.jpg)](https://blog.etcconnect.com/2022/04/a-console-with-extra-fluff-eos-apex-body-pillow)
[ETC Culture](https://blog.etcconnect.com/tag/etc-culture)
### [A console with extra fluff: Eos Apex body pillow](https://blog.etcconnect.com/2022/04/a-console-with-extra-fluff-eos-apex-body-pillow)
 By [Quinn Wirth](https://blog.etcconnect.com/author/quinn-buchanan) 1-Apr-2022
[Eos Apex](https://www.etcconnect.com/apex/) consoles offer the luxury of complete control, engineered for your comfort. But then we thought – what if we made them even more comfortable? Meet the Eos Apex body pillow. Nearly spanning...
[Read More](https://blog.etcconnect.com/2022/04/a-console-with-extra-fluff-eos-apex-body-pillow)
[![](https://blog.etcconnect.com/hubfs/Imported_Blog_Media/carlygillisphotography_JordansMailer_15.jpg)](https://blog.etcconnect.com/2018/06/etc-jordans-furniture-ropes-course)
[ETC](https://blog.etcconnect.com/tag/etc)
### [ETC climbs new heights at Jordan’s Furniture ropes course](https://blog.etcconnect.com/2018/06/etc-jordans-furniture-ropes-course)
 By [Quinn Wirth](https://blog.etcconnect.com/author/quinn-buchanan) 27-Jun-2018
ETC light fixtures have long lived in entertainment venues and retail spaces. Those two worlds collided as Jordan’s Furniture began building the world’s largest indoor ropes course as a part of its...
[Read More](https://blog.etcconnect.com/2018/06/etc-jordans-furniture-ropes-course)
```json
  "@type" : "BlogPosting",
  "author" : {
    "@type" : "Person",
    "name" : "Quinn Wirth",
    "url" : "https://blog.etcconnect.com/author/quinn-buchanan"
  "dateModified" : "2026-05-15T19:10:43.333Z",
  "datePublished" : "2026-04-02T14:00:00.000Z",
  "headline" : "IP Ratings Explained",
  "image" : [ "https://blog.etcconnect.com/hubfs/Lonestar%20Prime_rainfall-1.jpg" ],
  "mainEntityOfPage" : {
    "@id" : "https://blog.etcconnect.com/ip-ratings-explained",
    "@type" : "WebPage"
  "publisher" : {
    "@type" : "Organization",
    "logo" : {
      "@type" : "ImageObject",
    "name" : "ETC"
